Replace the small black tap on the back
Gear Sport, Blue'''
MODEL NUMBER: SM-R600SERIAL
The black tap on black is gone. Need a replacement? Can anyone fix or can I order this part? Thx
This is the only replacement that I could find.
https://rounded.com/samsung-gear-sport-s...
If you do not have one, you will need a tri-wing screw driver. You will also need a splunger or a guitar pick or playing card to pry the back open once you remove the screws.
Here is a simple tear down guide for the Samsung Gear Sport.
Hope this helps. Good luck.
这个答案有帮助吗?
This is wonderful..thank you, thank you, thank you! I have ordered the back and screw driver and I am sure I will check out the guide once they arrive!
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 12
总计 209
2条评论
It's not clear what part you are looking for. Can you provide a picture showing more detail? Thanks.
由 Joshua Freeman 完成的
Picture was added for clarity.
由 Lyn Hardway 完成的
