跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Microphone not working, no speaker calls
I replaced my screen on my iphone 6 plus. The new touch screen from ifixit works great. The home button works fine, camera works as well. However, I no longer have a working microphone. I can’t ask Siri anything, speak to someone on a phone call if the speaker is on, or dictate text messages, etc. Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Ensure the charging port is securely plugged in, or try a new charging flex to see if u get the mic working again. If just plugging it back in doesn't work just have a quick look at the bottom mics
完成的
添加一条评论
1个答案
My guess would be that in the repair you cut one of the microphone cables, jostled it from its position, or that it is no longer in its original place.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joshua Harner 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 33
