跳转到主内容
与AirPort Extreme基站一起发布,这款配备硬盘的Time Capsule NAS上提供802.11ac速度。
56 个问题 查看全部
Airport Time Capsule no longer connects to my network
My Airport Time Capsule no longer connects to my network. I was told that there is a chance the hard drive can be taken out and the data might be able to be saved to another drive. I have no idea where to start. I don’t care if the actual Time Capsule is torn apart as the TC is no longer of use to me. I downloaded your instructions on how to take it apart. Do I have to be careful as far as disconnecting the cables and power connector?
What do I need to purchase so that I can attach the TC hard drive to my MacBook?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
A 3.5” hard drive is used in the Time Capsule.
You'll need a 3.5” hard drive dock that is externally powered and provides USB connection.
这个答案有帮助吗?
得分 2
3条评论:
This is the SATA to USB adapter yo are speaking about StarTech 2.5" SATA to USB adapter cable
You'll need some recovery software to pull the data off as the files structure of the drive is not MacOS compatible.
完成的
Hmm. It's a 3.5mm hard drive installed though so the adapter won't have enough power to get the hard drive working off that adapter.
完成的
Good point! You'll need one with a power assist (external power)
完成的
添加一条评论
添加你的答案
Menthia Carpenter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 88
