跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
My ps4 turn on showing PS logo and then screen turn black
My PS4 fell down from a 2 m hight roof to floor.
Just open it to check, found safe mood screen asking to reinstall version 6 or later. Actully I been downloaded it from ps web site plus the complete ps4 software.
Installed version 6 with no progress, then installed the complete software then it restarted with ps logo then the screen turned black with no progress for few minutes the the ps4 turn itself off.
I tried all 7 options of the safe mood such defult setting, reintialized ps, etc. With the same result
Is this the APU problem as a result of falling down twice
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
My ps4 strated getting slow so i tried erasing some games and when i tried erasing fortnite it just kept frozen now it just shows me the PS sign and turn black screen like for 5 minutes than it turns
完成的
i did not drop my playstation all i did was try to restart it and it will pop up with the logo and go black then re pop up the logo but it lets me open safe mode menus
完成的
My PlayStation works fine until I go to open up a game and the game logo comes on then it goes to a black screen! Any ways to fix?
完成的
i was play my PlayStation just like any other day and it turned off out of nowhere and put me in safe mode and no matter what option i chose i comes up with the same thing the PlayStation logo
完成的
my ps4 for is broken
完成的
显示更多的3条评论
添加一条评论
8个答案
已选择的解决方案
The problem is going to be most likely the hard drive since APU faults will show no display + stuck on blue flashing light.
2M drop is pretty hard so that will be more than enough to kill the hard drive, I recommend getting the hard drive replaced and see how that goes.
更换PlayStation 4的硬盘
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket图片
产品
$29.99
这个答案有帮助吗?
得分 3
5条评论:
I hope so, getting another hard drive is easier than APU. thx
完成的
Can you play sometime and than it went blacked n controller disconnect?
完成的
Finally I fixed it, it was a problem with HDD.
I removed it from the console and connected to the laptop first it was't recognised and then used disc managment option to format and re-allocate to one partition volume as it was allocated to many partitions, then formated it with NTFS sys file, reinstall ps4 software and works fine but got errors when runing games disks. Then unfurtunatly currupted again.
Repeated all the steps before but change sys file to FAT32, reinstall and run, worked as a brand new with all game disks without any problems.
完成的
I have the same thing
完成的
If the logo is showing on screen, so its most propably a hard issue, replace it by new one
完成的
添加一条评论
Not an answer: my ps4 cannot start up and when i put it in safe mode and i initialize the ps4 when it finishes the ps logo comes yp and then it goes black with a blue flashing light.
这个答案有帮助吗?
得分 0
添加一条评论
That was my problem, try to change the hdd.
这个答案有帮助吗?
得分 0
添加一条评论
Mine shows a white light but dosent show display and mine didnt fall please help
这个答案有帮助吗?
得分 0
1条评论:
Ours did the same thing. Have you found a hard drive? And will all of the game stuff transfer?
完成的
添加一条评论
My PS4 broke 2 years ago after my brother spammed the power button we try to turn it back on but we can only go to safe mode once we try anything else even using the USB it will show the logo then go black with no display and no audio with a white flashing light so realizing the ps4 is broken we tried things I ended up pushing my ps4 which then started up the fan?!? Anyone else have weird problems like I ended getting a new ps4 slim also my old ps4 was the normal one not pro or slim
这个答案有帮助吗?
得分 0
添加一条评论
I had the same issue unfortunately you have to replace the hard drive it’s just the way it is. IT IZZZZ WHAT IT IZZZZZ!
这个答案有帮助吗?
得分 0
1条评论:
When I start up ps4 it goes straight to safe mode from black screen no ps log or anything I've tried update from usb and everything
完成的
添加一条评论
Bro this isn't the place for wannabe know it alls. Sometimes it's just not that easy. I'm having the same problem. The only issue is that I am using a new hard drive and it's doing the same thing. Obviously the answer is not replacing the hard drive DUUUHHHHH. ITT IZZ WHAT ITT IZZZZZ
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem. However I have a theory but have not been able to try it. Take the hard drive from another ps4 pro and clone that hdd to your hdd with a pc using SATA adapters and try if that works.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Someee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 43
总计 51,873
