跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Problem with getting sim card out
I forgot to put in this tiney part in and now i cant get the sim card out
How can i get the sim tray out
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The sim tray hole and ejection mechanism is there.
There isn’t anything populating that sim tray hole.
What part is it you are referring to? as I don’t see it in the images.
这个答案有帮助吗?
得分 2
8条评论:
So i forgot to put in the injection mechanism in a frame with a motherboard. How can i eject the sim card out of the motherboard without this mechanism ?
完成的
Oh I understand now, I was thinking it was still there since I saw it in the first image.
The sim tray can't be ejected properly without that ejection mechanism being there as it pushes the sim tray out when pressed on.
Without it you'd have to either open up the phone to remove the tray or have a tool that just fits snug in that hole to get it out.
Better replace the mechanism that was there if it's missing.
完成的
Can i use some force to put it out of the device ? or do you have any tips? because i dont want to damage anything.
完成的
With how snug the tray fits in, there isn't really a way to do it from outside of the device without damaging the housing or the tray.
完成的
And how can i do it from the inside?
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Mega Dealz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 9
总计 112
