跳转到主内容
Repair guides and support for your Philips TV.
243 个问题 查看全部
Part of LED TV I got is seemingly dead. Is this even repairable?
I got Philips 40PFT4100/12 LED TV from a cousin which did say that it had a display issue and it was the reason they replaced it.
What he said is that at beginning, “dead” part was a really small area which seemed like a really small dirt patch on screen and someone went and tried to wipe it off which resulted in “dead” area spreading and following the cloth used to wipe it. According to him, it wasn’t a big trail and was hardly noticable except, for example, when a face was behind the “dead” area. Eventually uncle got !#^&@@ off by it enough to go and buy new one but even according to him, TV was usable. Issue was just an annoyance.
So they brought it to my place, I set it up and turned it on. I don’t know did anything happen before or during transport to make it spread this much but this is beyond “annoying”.
Those lines weren’t mentioned when I talked to them and I couldn’t reproduce the “dead” area spreading by “wiping” the screen, be it hand, clotch, tshirt.
As mentioned in question, is this repairable and if yes, is it worth it? Honestly, I’m more interested in what may have been initial issue and why/how did it “spread”.
Apparently, Philips service partner is just down the street so I’ll check it out with them in few days when I’m free from work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
look like the internal panel has cracked...
not cost effective to replace imo
完成的
添加一条评论
1个答案
已选择的解决方案
Panel for this TV is bad and would need to be replaced but, cost of replacing the panel will cost more than getting another TV. Unless! You can find the same TV but with bad internal parts but good panel and just swap internal parts to TV with good panel.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
GroundDead 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 158
