跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Lightning to 3.5 mm cable shows "accessory not supported"
Hello everyone,
So yesterday, when i connected my headphones to my iphone 5c via the standard 3.5 mm headphone jack, but the output sound was like someone singing underwater. So today, i went and purchased a Lightning to 3.5 mm adapter and the audio plays fine for some time, then it abruptly stops and a popup shows up saying “this accessory is not supported“. What should i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
Does the cable plug go fully into the socket or is there a noticeable gap between the phone and the plug?
If there is a noticeable gap the charging socket needs to be cleaned with fine tweezers, or if needed a toothpick / sim pin eject tool. Be careful of the pins at the bottom of the charging port as they can be damaged if pushed against when cleaning the port.
For the headphone jack problem. The port either needs to be replaced or the housing replaced (if it is bent right at the headphone jack. It could also be the same problem of dust build up in the headphone jack port.
这个答案有帮助吗?
得分 2
1条评论:
Hello Ben,
I tried cleaning the charging port, but the problem still persists. After playing a song for 1 minute, It shows the message, "This accessory is not supported by this iphone". The adapter is non mfi.
完成的
添加一条评论
This accessory is not supported have the bad contact of cable to connector.There is possible resion.
1-Clean the connector might be dirty.
2-Change the charging flex.
3-Charging cable itself might be problem.
4-Trister might be also problem,This need microsoldering skills.
这个答案有帮助吗?
得分 1
添加一条评论
These answers are bullshit!
it’s a software issue! and the culprit is Apple Company itself! Just buy an Apple certified adapter and it will work perfectly! In short: ( the headphone adapter you used isn’t genuine!)
这个答案有帮助吗?
得分 1
1条评论:
I have several Apple Certified adapters that no longer work as expected. I get no warning that the adapter is not working. 14.1 and newer iOS updates do not fix or have actually caused the issue. Apple needs to fix this and stop breaking its own rules. It is so infuriating to deal with Apple thinking they need to step away from industry standards.
完成的
添加一条评论
No. These solutions don’t work. Apple is breaking the trust of the customers by enforcing these rules through software. If the contact is dirty or loose then how does the music play for one minute and gets cut exactly at one minute timeframe every time. Is the dirt or loose connection so smart to take effect every one minute
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Saikiran Bait 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 45
总计 6,129
