One of the wires leading to the right earpiece is cut
Lost my headphones in the ground long time ago, it worked fine for a while with som tape. But finally one of the wires leading to the right earpiece got cut in half. How can I repair this wire?
It’s a bit tricky to tell from the photo but you should be able to solder this connection back together again.
Soldering is relatively simple, but you’ll need a soldering iron, and some solder to do it. You’ll also want to cut back the wrapping on the wire as to make sure you can get a good amount of wire. As an alternative you could also buy a cheap wire connector and just splice the two sides together… this isn’t a great way to fix this issue though.
这个答案有帮助吗?
Is there a diagram that shows which wires connect to which? I'm having the same issue
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 287
