跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Water stuck in camera module
My mom recently broke her iphone 8 and decided to get a new one and I fixed the 8 and am now using it as my main driver. The phone had severe water damage and I have since replaced the screen, but water still remains within the actual camera lense on the rear part of the phone. I have taken the camera out and tried drying it with a hair dryer, but the water remains. Is there any way to fix it? Or to buy a new camera?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If the glass lens visually looks clean on both the camera and the glass on the iPhone then the rear camera will need to be replaced.
You could try blowing some hot air on the rear camera with a hair dryer for a few seconds and see if that helps.
这个答案有帮助吗?
得分 1
添加一条评论
If trying the dry the component with the hair dryer didn’t work then it may mean you just need to replace the rear facing camera module. You could try using some isopropyl alcohol (at least 91%) to see if that will displace the water then use the hair dryer again to evaporate the alcohol.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Riley Muir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 1,032
