跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Power / Boot Issues
I have been trying to figure this out but can’t.
The Mac is being quite unpredictable when it is powered on. I have removed the screen to get to the diagnostic LEDs and to change the internal battery.
Basically, when power is plugged in LED 1 is lit up - that is the same no matter what. When the power button is pressed, some times LED 2 will flash on and off, sometimes it stays on for a few seconds and goes off and sometimes it stays on until I turn it off.
The fan will kick in at full speed when the computer stays on for more than a few seconds. There was one time after removing the on board battery when it came on and chimed, then LED 3 was on. It was very dim but it was lit. haven’t been able to get that to happen since.
I have tried removing and re seating the RAM and changed out the sticks without any change.
Any Suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Not sure I follow your reasoning on replacing the PRAM battery. The battery only holds the settings when the system has become unplugged.
完成的
What happened at the very start. Did the system not turn on in the morning? Did you leave it running and in the morning found it had turned off? Where you in the middle of something and it went dead?
Do you have a surge suppressor or a UPS and are all of the peripherals plugged into the same suppressor or UPS?
完成的
Hi, thanks for the reply. I was reading that the third diagnostic light off could mean there was an issue with the battery so I replaced it as a matter of course, being that it's easy to do I tried it just to get that troubleshooting step out of the way. I also noticed the old battery was reading just over 2 volts so I thought it was worth a try.
The computer has been a problem for a while. At first it wouldn't turn on in the morning without resetting the SMC. That started getting worse and I was resetting it up to 10 times before the system would boot in the end but now its not booting at all. The computer is plugged into a standard 4 way power cable without surge protection. Any help would be appreciated.
完成的
So I currently have the dim 3rd led status. Power supply?? Thanks!
完成的
添加一条评论
1个答案
已选择的解决方案
Sadly I’m suspecting your power supply has failed. Even though you have a surge suppressor it might have failed you. I would also recommend replacing the surge suppressor with a good quality unit or better yet getting a good UPS.
For reference here’s a full breakdown on the diagnostic LED’s
  • LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
  • LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
  • LED 3 - Indicates that the computer and the dedicated GPU are communicating. This LED will be ON when the computer is communicating properly with the dedicated GPU. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the logic board is in need replacement.
  • LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or cables from it might be installed incorrectly or need replacement.
Here’s the needed part iMac Intel 27" (Late 2012-2020) Power Supply and here’s the guide to put it in iMac Intel 27 英寸 Retina 5K 显示屏电源更换
Replace the power supply for a Model A1419 Late 2012 to Mid 2017 or Model A2115 Mid 2019 to 2020 27" iMac.图片
产品
$99.99
这个答案有帮助吗?
得分 2
4条评论:
Thanks, is there any way to test the PSU to confirm this is the case? Are there any telltale signs to look for or testing point that I can test the voltage of? Thanks!
完成的
As LED is not lit I don't think you have any other way without having a second test system.
完成的
OK Thanks for your help Dan, I will explore a few options and see about replacing the PSU. Will let you know if it worked.
完成的
I managed to borrow a PSU from a working iMac and it worked so that is definately the issue here. Thanks for your help!
完成的
添加一条评论
添加你的答案
Whisky Lima 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 30
总计 1,850
