跳转到主内容
The 2005 version of Volkswagen Beetle is the upgraded version of the 1998 edition, which obviously came with a large number of improvements and advanced features.
11 个问题 查看全部
How do I get AUX input out of the body of the car?
The AUX input has been knocked inside the body on the inside of the car. Does anyone know how I can get it out?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
So if you fit the plug in it will toggle side to side or it goes in but you don't feel the detent?
完成的
Hi Dan, the AUX input used to be where that black hole is now. The input was pushed inside and I'm not sure how to get it out
完成的
We’re is the aux located ?
完成的
添加一条评论
2个答案
已选择的解决方案
This YouTube video shows how to take the center dash off for the Volkswagen Beetle 1998-2010.
这个答案有帮助吗?
得分 2
3条评论:
Hi Joshua, thanks for this. I'm not sure I'll be able to get to where the AUX cable is via the area where the centre dash is though
完成的
Ryan,
You are going to need to remove the center dash just to put the AUX port back in. Once you have the dash off, you can look and see where the port has fallen. This will provide you with more room to work with rather than trying to go in from the bottom.
完成的
It maybe cracked so the part is not secured or the socket maybe broken. The test I had offered to you would give you a clue which way things are likely to go.
If you can wiggle the plug side to side the socket is not mounted to the panel.
If you don't feel the detent (comparing to another device) then the socket has failed.
完成的
添加一条评论
Dash is usually easy to get off .has screws or clips holding it in place. Check u tube for your car model and then replace jack and glue bk into place.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan Ball 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 74
总计 6,289
