跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 个问题 查看全部
2013 MacBook Pro 15" Retina powers on with cable, but not batter alone
Hi guys,
I recently dropped my 15” Early 2013 Macbook Pro Retina and it landed on the right corner. Now, it won’t turn on, unless it’s plugged in to a power source.
I recently went in and disconnected all the wires and reconnected them, still same problem.
Here’s my system report - Charge Information:
  •   Charge Remaining (mAh): 7783
  •   Fully Charged: Yes
  •   Charging: No
  •   Full Charge Capacity (mAh): 7981
  •   Health Information:
  •   Cycle Count: 53
  •   Condition: Replace Now
  •   Battery Installed: Yes
  •   Amperage (mA): 0
  •   Voltage (mV): 12415
Does anybody have a solution to this?
Do I just need a new battery, or is there an easier solution to this problem?
Note: The low cycle count is because I replaced the battery just 6 months ago.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Condition: Replace Now - Is a good clue this battery has issues. As you just replaced it I would contact the person who sold you the battery for an exchange as its likely defective.
这个答案有帮助吗?
得分 1
1条评论:
Thanks @danj, I purchased from here and already have a warranty battery on the way
完成的
添加一条评论
That might be either a problem with the charger, or a problem with one of the connections from the charger to the battery.
这个答案有帮助吗?
得分 0
2条评论:
Battery shows 100% charged when I’m powered on (which can only happen when plugged in.
完成的
@drochwalik Then it means that the battery isn't retaining any charge, which means that the battery needs to be replaced. However, don't take it to apple, they will probably overcharge for it. If you want to fix it yourself, try looking at a teardown.
完成的
添加一条评论
添加你的答案
Derrik Rochwalik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 61
