跳转到主内容
Computer not recognizing iPhone ANYWHERE
Hi,
I have use NZXT computer at work, and no matter what I’ve done (tried switching ports, plugs, even different iPhones) when I plug my iPhone into my computer, it doesn’t recognize it at all- aside from charging it. It doesn’t show up in Device Manager, doesn’t come up in iTunes, or any other folder or location that I’ve come across in various online forum suggestions. It’s as if the computer has no idea that anything is even attached to it.
Can anyone help me diagnose what may be going on and how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Have you checked in the bios? You might need to brute format a version of your phone’s storage before you can be able to access any of the data, due to how apple locks down their lightning charger, and make it nearly impossible to transfer files from you phone to your computer, or vise versa.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the response. How do I do this?
完成的
Actually, you don't need to go into the bios. Try going into disk management. Do you see your phone storage amount in the disk management software? Sorry for taking a while to come back.
完成的
添加一条评论
It could be because file transfer has not been enabled on your iPhone. When you connect your phone to your computer, swipe down from the top of the screen and see if it offers a list of options for what to do with the connection. Data transfer should be one of the options.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the answer. Usually when an iPhone is recognized by a computer, a little box comes up prompting you to allow it to access your photos. This box doesn't come up. Also, in the past when I've experienced non-connection issues, my phone has at least showed up in other internal areas. Not here. It's absolutely nowhere on my computer, at all.
完成的
添加一条评论
添加你的答案
Diana A 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 106
