跳转到主内容
苹果AirPods是于2016年12月发布的无线耳机。
94 个问题 查看全部
Case not working. Only when charging
My airpods case does not light up when I open the case. But if a put a charger in the light flashes white really fast. And my airpods is on right now and I don't know how to turn they off. Because my case doesn't do anything
Plz help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
Mine don’t even light up while charging
完成的
添加一条评论
5个答案
已选择的解决方案
There may be a problem with your Airpods case then, and it probably can’t retain any charge, so, it only works when it is plugged in, when the energy is going purely into charging the airpods rather than charging the case.
这个答案有帮助吗?
得分 2
2条评论:
I my case, when it's plugged on charged, it show 100% of charge. I think that if it was a charge retention issue, it would display a critical level of charge instead of showing it fully charged.
One more thing, if I keep the box plugged, I am able to connect the airpods and they are fully charge too. If I remove the box from charge the airpods can't connect.
完成的
samething with ming
完成的
添加一条评论
My airpods have a orange light when they are charging but when i try to use them the light turns off and they won’t connect. I recently dropped my AirPods case and it has a scratch on it but I don’t think it’s that. Any tips?
这个答案有帮助吗?
得分 1
1条评论:
I have the same issue too.
完成的
添加一条评论
You need to replace the case in this situation. I had faced the same problem and as my airpods were not under warranty, i need to pay 1200 indian rupees for the same.
这个答案有帮助吗?
得分 0
1条评论:
yeah they told me the same thing, $179 USD (12603 Indian Rupees) to replace them
完成的
添加一条评论
In my nothing ear 1 charging case, TWS pogo pins are not working. is it possible to repair? Amy spare parts available? Please let me know
这个答案有帮助吗?
得分 0
添加一条评论
for me was my connection pins in a case had corrosion after i rubbed votka and use my screw drive i was able to do the fix.
i know it sound bad advice.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Isak_holmgard 将永远感激不已
浏览统计数据:
过去 24 小时: 26
过去 7 天: 163
过去 30 天: 704
总计 50,030
