跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 个问题 查看全部
Apple firmware hard drive replacement?
I have to replace the 3TB seagate drive on my iMac 27” 2014 retina. I have Mojave installed on the separate 128GB blade ssd.
Is there a hard drive that will work on the iMac without the fans going crazy? I heard the drive needs to have apple firmware.
Just want to pop a cheap spinning drive inside for storage. I don’t wanna spend the dough on the thermal sensor.
My other option is buying a 1TB ssd but then I would need the thermal sensor.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
The newer iMac’s 2013 onward appear not to need the thermal sensor. The age of the drive you use also is a factor! If you are using a newer generation you’ll be OK as they are using the newest version of SMART services.
I would recommend going with a Seagate FireCuda as the best drive you can get.
I’m not a fan of the higher 3 TB and larger HDD’s as they tend to need more power & cooling than what this system can offer. Besides putting your data at risk. Don’t forget your external Thunderbolt ports are much faster than the SATA III (6.0 Gb/s) interface!
Do make sure your system is not currently setup in a Fusion Drive set. As that will complicate things.
这个答案有帮助吗?
得分 3
3条评论:
That's great. Thank you. I have the 128GB ssd as a stand alone boot drive, that originally was the fusion drive coupled with the 3TB.
If going for an SSD, the thermal sensor from OWC would be needed though?
Only new enough HDD's can do without?
完成的
Make sure you reformat the SSD drive before you use it again.
Both HDD's & SSD' that comply with the newest SMART standard are workable.
完成的
Thanks. How do I know what the newest S.M.A.R.T. standard is? I am looking at the Samsung EVO 860 and Crucial MX500, do you know if they will work without the sensor?
完成的
添加一条评论
This is probably not the best solution but you can use the Macs fan control app to adjust the hard drive fan speed so that it is not noisy after loading MacOS.
这个答案有帮助吗?
得分 2
添加一条评论
Is this also the case with a late 2012 iMac? I need to replace the HDD and am also worried about fan/temp.
这个答案有帮助吗?
得分 0
1条评论:
So a VW bug engine will fit your ford T-bird? Just like them your system is very different than the system being discussed here.
In your case you will need this in-line sensor: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later and you want to follow this guide iMac Intel 27寸 EMC 2546显示屏替换 Be very careful as its very easy to damage the display if you don't use the special iMac Opening Wheel tool and Plastic Cards and follow the instructions to the letter.
完成的
添加一条评论
添加你的答案
robert 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 6
总计 467
