Alesis SamplePad - Common blue-display bricked device > seeking repair
Polling the experts for a solution to this very common error on these original Alesis SamplePad devices. There is a history with these drum pads dying with this blue-screen failure where they are non-responsive. No error displayed on the screen, attempts at a factory reset are not successful. The vendor will not comment directly and will only send customers over to their service group to get a quote for non/warranty repairs. Does anyone have a fix or experience with this unit they can share?? Customer options seem to be either re-paying 80% of the original purchase price to hopefully get their unit magically returned in a functional state and hope for the best going forward, or discard and replace with a current model….
Any advice, schematics, or experience would be greatly appreciated.
Update (11/24/2019)
FYI: Still no luck chasing this one down. No YouTube hacks have been found and I have recently reached out to Alesis parts department about the error and their ability to identify/provide the proper part for this common failure. I also reached out to their sub-contracted East Coast service center to see if they could provide any technical assistance. (To give this private business credit, they were skilled and quite knowledgeable when I last visited with a bandmate’s gear and their store/shop was a very interesting museum-like collection of rebuilt and repaired instruments from decades past. I suspect they have also paid their due to Alesis to have the privilege of servicing their instruments… :(
I just received a repair estimate from the Alexis service center. No itemized parts, no breakdown on labor, no technical info... Just an estimate for $120. SMH.
由 Gary 完成的
Sorry, still haven't found the time to replace @30 caps, but I did see this video in the meantime which may be the clue for some; intermittent power jack;
https://youtu.be/JMAB8oW2ZXY
It seems his issue is simply a bad solder and only showing blue screen just before boot.
Unfortunately was not my issue as in fact, my jack is also sturdily zip-tied to the board!
由 JIMBOMU 完成的
Same problem, I've replaced PSU capacitors with no change, next I'm going to try replacing all the rest of the caps and see what happens
由 JIMBOMU 完成的
Thank you Jimbomu. I would love to hear your findings. Best of luck with the teardown. I am still shocked with such a common failure for these devices how little information seems to exist around the error and resolution.
Much appreciated,
-Gary
由 Gary 完成的
I gave up, too much de-/soldering for me - will sell mine for parts..
I did see another video meantime where a fellow discovered he had the blue-screen problem because of an apparently too-long mounting screw on the back had damaged one of the sms elements on the pcb (he did not attempt repair). Alas, that did not seem to my issue.
由 JIMBOMU 完成的
