跳转到主内容
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 个问题 查看全部
I want to know Bluetooth module pinout for iMac 9,1
I can’t seem to find the pinout for my Bluetooth module (BCM92046MD), as per photo:
In particular I need to know which pins are for D- and D+
Background:
In an attempt to activate Handoff/Continuity, I’ve installed a BCM94331CD wifi-bluetooth combo card.
Wifi works fine, but bluetooth is unrecognised by System Profiler. That suggests to me that I need to connect to D-/D+ cables to my my wifi card adapter. I soldered up a dongle to what I thought were the D-/D+ lines on the old bluetooth cable socket. But when I tried to boot, I only got a chime, a white screen, and no further. So, I may have got the pins mixed up.
Any help would be greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You really need the combo card Broadcom BCM94360CD. Activating the Bluetooth on it. Take the current BT card out.
This is what I used iMac 2009, iMac 2010 and iMac 2011 – Apple Broadcom BCM94360CD – 802.11 a/b/g/n/ac with Bluetooth 4.0 kit
这个答案有帮助吗?
得分 2
2条评论:
Thanks Dan, but my understanding is that BCM94331CD is a combo card (same as BMC94360CD, but with Wireless-N).
Anyway, I think I found the pinouts here:
http://homokozo.czo.hu/iMac2011mod/iMac2...
完成的
Yes, the board you have is the older one. I was not able to get it to work. But the real issue is the Bluetooth services on the combo board need to be used not using the older BT board. The kit is what you need as it offers the needed extension cables and the USB power & data connection the BT services uses.
完成的
添加一条评论
添加你的答案
Andrew Vines 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 857
