跳转到主内容
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 个问题 查看全部
What type of gear oil do you use in a fa50?
what type of gear oil do you use in a fa50? just got scooter and previous owner knew very little about it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
the manual says to use 500ml (.5qt) of 20-40, another person says 10-30 synthetic could improve top end
这个答案有帮助吗?
得分 3
1条评论:
Straight from the service manual: Transmission oil--Use a good quality SAE 20W/40 multigrade motor oil.
完成的
添加一条评论
The FA50 should only have 10w30 oil. Whether normal or synthetic will not make any difference to the performance. Too much oil will cause problems so measure carefully. The gear train sits in the oil and so does the clutch. Replace the oil once a year at least. I often add a little oi additive like Slick50 or Motorcoat to keep the gears well lubricated.
这个答案有帮助吗?
得分 3
添加一条评论
use the lighter gear oil and the web sights says to use only 300ml of gear oil to add 3-5 mph on the scoot. they sd that 500ml is to much and causes drag in the gears. using 300ml will run great and protect as well as 500ml good luck
这个答案有帮助吗?
得分 1
添加一条评论
from 80/90 gear oil to 10/30 which one and how much?????
这个答案有帮助吗?
得分 0
添加一条评论
That depends on a few things, like altitude and the atmospheric temperature. Most times, anything on 2 wheels will do fine with a 80w90 gear oil. If you can find. You can find this at any automotive-supply store, or anywhere with a decent automotive department.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
SHELLEY 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 90
总计 13,594
