跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Does my ps4 overheat cuz I put it on rest mode to let things update?
My brother said that i fudged up the ps4 because i left it on rest mode multiple times to update/install games.i dont think thats the case, could anyone help me out.PLEASE
THANKS IN ADVANCED.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
What exactly is happening with your system? Just so people can get an understanding of what's going on?
完成的
添加一条评论
4个答案
已选择的解决方案
Overheating can happen due to improve/insufficient air circulation around the PS4. I used to face similar issue, when my PS4 used to remain ON for extended time of period (paused game, downlading or updation). I solved the issue by keeping the PS4 in open and leaving 1-2 feets space between back side and the wall. Now, I use a external mini USB fan, placed on top of PS4 to keep it cool.
这个答案有帮助吗?
得分 1
2条评论:
Lots of times it could be caused by the console never being cleaned from the inside. Dust build up gets pretty bad past 2 years from date of purchase. They should be cleaned at least once every 1-2 years.
The part that fails first from dust is usually the power supply, random shutdowns are the first signs of power supply failure.
Other one worse case scenario is blue light of death but that is unlikely.
In most cases it usually is the fan ending up very noisy all the time during gaming which cleaning the console internally and replacing the old thermal paste will fix.
完成的
So if my ps4 has good air flow its fine
完成的
添加一条评论
I leave my ps4 on rest mode almost all the time. I also have it set for auto updates and it hasn’t acted up at all, I’ve also had my PlayStation for like 3 or 4 years. So I don’t think that would be your issue, rest mode was made for when you’re not using your console, the only downside is that it wastes a more electricity
这个答案有帮助吗?
得分 0
添加一条评论
No dude ot may cause of u leave the ps4 for 1 week straight.for eg. Downloading warzone. it takes a long time right cause its 100 gb so people with slow internet. So they keep it all day everyday. Cause when i was downloading and i kept it for 4 days for restmode. It heated so bad
这个答案有帮助吗?
得分 0
添加一条评论
I went to another country and left my ps4 on for like a month and it is now overheating so what shall I do.I cleaned the fan bit not that much so what else shall I do pls someone help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ArguloGaming 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 8,574
