跳转到主内容
The Amazon Fire HD 8 (5th Generation) is a sleek, black tablet released by Amazon in September 2015. Model Number: SG98EG.
Why is my Kindle stuck on fire screen?
My Kindle worked fine one day and the next am was stuck on the fire screen. Two days later, my Mom's Kindle did the same thing. Both are charged and no matter how many times I press the power and volume buttons; it always returns to the fire screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
最有帮助的答案
Charge your device for at least 30 minutes and try to restart your device again:
  • Press and hold the Power button for 40 seconds.
  • If the device restarts before 40 seconds has passed, release the Power button.
  • If the device doesn’t restart, release the Power button, and then press the Power button again to turn on the device.
If the issue persists, attempt to Factory Reset using the built in device recovery mode:
  • Power device down completely via the Power Button. If the device is unresponsive to the 2-second Power Button press, attempt the 40-second Power Button press, which should cause full shutdown.
  • Make sure your device screen is completely off with no activity.
  • Enter Recovery Mode by pressing and holding Power+Volume Down for 5 seconds.
  • Once in recovery mode, use the volume keys to navigate to "wipe data/factory reset," and the power button to select it.
Please note that a factory reset will remove any content you have downloaded to your tablet.
这个答案有帮助吗?
得分 1
添加一条评论
what to do with my kindle oasis frozen at tree screen, not opening home screen
这个答案有帮助吗?
得分 1
添加一条评论
I have the same issue have been trying for 3 days now. I have done even a factory reset and no luck
这个答案有帮助吗?
得分 0
3条评论:
My tablet is the same have done all the reset, reboot, etc..suggested it will not repair. Stuck on Fire loading screen.
完成的
Ditto - totally frozen
完成的
Wont even go far along enough to show me the charge, but i know it has enough power to show me the amazon logo nonstop
完成的
添加一条评论
I am not a teckie, but my 2¢ worth logic works.
When you switch on, press 20 sec or less only. This will initiate the start. Pressing more than 20 sec causes hanging.
To get out of hanging screen, press the on button for min of 40 sec.
这个答案有帮助吗?
得分 0
添加一条评论
Please help. I read somewhere that the battery may be fired and if so, it will erase all of my books. Pleas help:-(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shelbi Stoecklin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 29,435
