跳转到主内容
加入维修社区 - 创建账户
The Lenovo IdeaPad Yoga 11S is a 2015 2-in-1 convertible laptop with an 11.6” multi-touch display.
Lenovo IdeaPad 11s: What size torque screwdriver is required?
Looking at the tutorials, it states you only need a Philips #0 but you need a torque screwdriver but I don't know what size is required? Lenovo IdeaPad 11s
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
From some research it looks like it might be a Torx 5. A lot of electronics are T3-T6 I’ve noticed, with the exception of some. Try the T5 though!
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
Torque screwdrivers are used to prevent under tightening of the screw causing it to not hold correctly or over tightening of the screw which may damage the thread or head of the screw.
Looking online torque screwdrivers are not cheap and are usually used by professional repairers as their frequent use justifies the cost of the screwdriver.
If you are doing a one-off repair, it may be just as well to use the appropriate sized screwdriver and simply slug the screws up tight, without overtightening them or damaging the screwhead
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Killian 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 57
总计 2,791
