跳转到主内容
The Apple Extended Keyboard is a USB-A extended keyboard with an aluminum body and a numeric keypad.
5 个问题 查看全部
Need Help Placing large zero key back.
Is there a walkthrough for the Apple Wired Aluminum keyboard extended model MB110LL/A to replace the large zero key on the 10-key number side? I have tried everything and cannot figure out how to put it back on. And strangely enough there is no tutorials or videos on the internet anywhere. I really don’t want to go to the apple store for them to reattach a key.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I need help also. The answer from Dan did not help me. The cap from number 0 I cannot fix on.
完成的
添加一条评论
1个答案
最有帮助的答案
Here’s a good site that offers the needed parts and the guides to put the key caps back on Aluminium USB Keyboard
这个答案有帮助吗?
得分 1
4条评论:
Thanks for your comment. I see where I can purchase parts but I do not see any tutorial in which to put the key back on. That is all I need since I already have the keys.
完成的
Opps! They took the guide away.
Here's a Vid that should help you Removing apple mac keyboard keys
完成的
Hi, this link has no answer for my extende magic keyboard. The cap for number 0 keeps falling off. I do not find any answers.
完成的
@norbertus - If you look carefully you’ll see the keyboard uses the same design. Order the needed key parts and give the new ones try.
Otherwise you’ll need to visit an Apple Store or authorized resellers for them to help you.
完成的
添加一条评论
添加你的答案
Frank Spalding 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 441
