跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
Need to find the power button switch connector
Need to locate the power button connector to board. I want to splice into it and connect to a  Sonoff 4CH Pro R2 Smart Switch, Interlock Switch for Generator, Including/Self-locking WiFi & RF Wireless Switch. And be able to turn the iMac on from anywhere.
I have done this on my Windows PC easily and was hoping the same with my iMac.
I’m sure I will need to drill a small hole for the wire to come out.  Maybe even put a two wire connector in the hole, for unplugging and plugging in the sonoff.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You do realize the iMac can be woken from network.
A simpler way to manage your system is to just connect your system to a UPS. Letting the UPS manage your iMac. Turning it off and if needed on.
这个答案有帮助吗?
得分 0
4条评论:
Yes I did think of this, I would need to run a cat6 cable 150ft, which is not an easy task. When I can use the Sonoff. I use sonoff for many different things including my alarm system, lights, pool, driveway gate and 2 pc's and garage doors. I would like to be able to wire it for the iMac also.
Thank you for your input :)
完成的
You don't need Cat6 cable if thats the issue Cat5 or Cat5e will be just fine as you only need a 10BaseT connection (10 mbps).
But, instead of a wired connection how about just using WiFi via an extender between the two points.
完成的
I was of the understanding you cant do this over wifi. Even if I could then yes I would need to add a ups to the computer in case power outage. I will look into this thank you. But I still want to know where the power switch connector on the mb or logic board is located. Maybe I'm asking this on the wrong forum?
完成的
I have Eero base units which will pass the connection bi-directionally. Basically, a wired extension (E-Net <> WiFi <> E-net) as I have a UPS for my Mac Mini as well as iMac I have my iMac and Mac Pro turn on my Mac Mini and then run a backup program so my Mac's are then backed up onto the mini's external RAID drives.
To be clear here the systems are wired not using WiFi directly.
完成的
添加一条评论
添加你的答案
Bill Hughes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 81
