跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
I need to disengage from iCloud
I need to disengage from iCloud since they are fleecing us.
I have my own separate backup hard disk, kindly guide me how should break the iCloud connection and still have the backup for an uninterrupted free flow of data
Thank You!
Narayanan Lakshmanan, India
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here’s a good write up! How to set up and access iCloud Drive on the Mac
But before you break the connection you’ll want to make a copy of whats on your iCloud drive presently. Go to the dock and locate the iCloud Drive icon to open the finder in that view drag copy it to your local backup drive. You might want to do a few folders at a time so you don’t lock up your connection in case you need to do something else. It can take a bit of time depending on your connection.
Once done make a Time Machine backup or use what ever backup application you feel comfortable with. Do take the time to check it is really backing up and you can recover your data either a full restore or selectively.
You want to delete your iCould data follow this Apple T/N Manage your iCloud storage and then once all your data is off break the connection from the guide.
Don’t forget to contact Apple to cancel your account so you aren’t billed for the service any more. Do consider your iPhone or iPad maybe using iCloud as well. So canceling it fully might be a problem. You may want to just roll back the size you are using.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
NARAYANAN LAKSHMANAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 65
