跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
How to bypass activation lock
How to bypass activation lock for iphone s6+
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Actually you need to replace the CPU/NAND/ Baseband CPU and EEPROM. The skill level required to do this consistently is pretty much unheard of in NA and western Europe and the cost factor makes it unviable in almost all situations except where data recovery is extremely important and you are willing to pay a higher price to achieve it.
This can be done more cost effectively on China.
这个答案有帮助吗?
得分 2
添加一条评论
You will need to replace the NAND, baseband, and baseband memory ICs on the logic board. The chips are BGA-soldered so you will need BGA solder reflow skills and equipment to replace them.
这个答案有帮助吗?
得分 0
1条评论:
I was confused so can you help me understand a little bit better?
完成的
添加一条评论
I was confused so can you help me understand a little bit better please?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Greg Pate 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 380
