跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Backlight filters / diodes
I have a question regarding the filters and diodes on an ipad air wi-fi.
This is my first attempt to fix this kind of thing, so bear with me please because i am still trying to learn things.
So, the backlight is sometimes working (barely, left side has 50% “flashlight”) and sometimes isnt at all. (the right side of the screens seems fine)
The damage came from a blown lcd connector that burned filter L7085
If i measure both diodes D8258 and D8228, they read out somewhere around 0.6 or 0.7 (out of my head) and they do not seem cracked or whatsoever.
The filters though, at least one of them (the right one) looked bad, but i changed both of them with used filters from a donor and the backlight started working again on a new lcd, only to have it malfunction again after a few power button standby clicks.
My main question, when i measure backlight filters, do they need continuity or not?
I have always thought they did have to have continuity?
And if it does, does this count for basicly all filters on iphones aswell as ipads?
I am asking this because i bought some brand new filters off a chinese supplier but i get the feeling they didnt send me filters at all but something else. When i measure them they do not have continuity.
What is going on here?
The weird thing is, both filters on the ipad did not have continuity but the backlight still worked for a while, after it stopped working, nothing changed. Though, the filters didnt look blown again but also didnt have continuity. This is why i am so confused!
As a side question.. I did saw that one of the filters (L7085) has a bad/damaged pad/trace on the left side wich barely makes contact.
So just to be sure to have a second option on this; Seeing as L7085 is connected to D8228-K, if i was to make a jumper from L7085 to D8228-K, would this be acceptable?
Or would it be better to make it jump to C8250/1/2/3 or 4?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
8条评论
Filters are basically like a thin wire that is supposed to blow after a certain amount goes through it like a fuse... so yes they have continuity u may have diodes if they only allow continuity one way.
完成的
Makes sense. So the "filters" they sent me were probably resistors? I just fchecked for continuity and they didnt have it.
Any idea on if i was to make the jumper if this would be acceptable and safe?
完成的
I havent got zxw with me or phoneboard, lol in bed eating snickers can check for u in the morning or @refectio may come up with answer before then :)
The filters are supposed to act like fuses and blow to protect the backlight circuit you could just use a blob of solder or a wire in their place to test however it's not recommended as this will usually blow the rest of the circuit if there is a problem in the future...
P.s filters are 0 ohm resistors :)
完成的
@c9679 ...is that a challenge? :>)
完成的
@refectio lol I thought u might have zxw memorized by now :) my brain cant retain the names of these things anymore lol
完成的
显示更多的3条评论
添加一条评论
1个答案
已选择的解决方案
Ferrite Beads (aka filters) are very low resistance (short) in DC. That means when you measure them with a multimeter, they will show 0 Ohms. They become resistive at high frequencies and are really used to filter out high frequency noise.
Take a look at this classic filter. You’ll note that the specs are 240 Ohms of resistance at 100 Mhz and that they can sustain 350mA of current. In DC mode, it will measure 380 mOhms (hence why they appear “short” or have “continuity”.
Don’t order these from Chinese vendors, they are easily accessible via reputable suppliers like DigiKey and Mouser and cost usually just a few pennies.
As for your jumper, both options are good, just select the easier path.
这个答案有帮助吗?
得分 4
2条评论:
Never mind my earlier comment...
Yes these will do but you need the 0201 package size.
完成的
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 31
总计 1,025
