跳转到主内容
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
114 个问题 查看全部
It works but no sound
I found my chilhood N64 and it did’t work, so I cleaned it and it worked but no sound. I have checked the cables and conectors with a multimeter and they are fine. In my research to find a solution I have found that the capacitors that process the audio might need replacing and that HDMI ultra mod bypasses this problem and does the processing on its own. The HDMI mod its way too expensive for me, so my question is: wich capacitors I have to replace on the board and how do I do it without messing up my N64?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Double check the solder joints on the AV port for any cracks etc. is broke, here is the guide for the port. Check components around U1 which is your MAV-IC Digital to Analog converter (DAC) video/audio. Let us know what you find.
这个答案有帮助吗?
得分 0
2条评论:
I have tested the continuity from the board to the end of the cable with a mutimeter, I don't think that's the problem.
完成的
I have the same problem and haven't been able to figure it out, about to buy a new one.
完成的
添加一条评论
添加你的答案
machitocayo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 41
总计 2,528
