跳转到主内容
won`t power on when charger connected.
my mac wont turn on while charger connected. Only powered on by removing the charger and after power on every thing works fine and battery is also charging fine no issues. And some times wont came out from sleep
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would follow apples guide it could be a PRAM reset or NVRAM reset
https://support.apple.com/en-us/HT204267
It sounds like something is causing a short so you can try to replace the charging port itself before doing that and spending the money try apples guide then if that doesn’t work backup and do a factory reset.
这个答案有帮助吗?
得分 0
4条评论:
I tried it already but didn't worked
完成的
Have you tried the charging port?
https://www.ebay.com/i/141524554529?chn=...
完成的
replaced with my friends mac didn't solve the issue i think its bios chip( bcoz some times it wont turn on from sleep)
完成的
oh yeah it fairly well could be.
完成的
添加一条评论
添加你的答案
Avinash 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 53
