跳转到主内容
Repair guides for the Samsung J7 Pro. Learn how to repair your Samsung J7 Pro on your own.
20 个问题 查看全部
Why when my phone rings it makes my notification sound
Hi I have a Samsung J8 and my problem is that when my phone rings instead of hearing my ringtone I hear my notification sound. I tried almost everything and nothing is working so if u have a suggest can u plz help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
are you able to hear music/ sound when watching videos? if you aren’t able to then there could be a problem with your speaker and that will have to be replaced. if it does work then there could be something going on in your settings if you go to settings then sound you can find the setting there. If that still doesn’t fix the issue I would backup your phone then do a factory reset.
这个答案有帮助吗?
得分 1
2条评论:
Thank you so much. The factory reset worked. Thz ❤❤❤
完成的
glad to hear, you're welcome.
完成的
添加一条评论
添加你的答案
Kelaiah Latchman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 7
总计 697
