跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
I need to change the battery guide me please
I need to change the battery it is very expensive in India,
I also understand that we should change the case is it possible to do it myself? I also understand there is procedure that we can change the battery without the case, since I 'm from India I will request one of my friends who is coming from U.S to purchase a battery for me from your outlet.
I’m also equally annoyed by their backup procedure with i Cloud which is quite expensive, I have my own spare Hard Disk
I need a procedure to dispense off iCloud permanently and a link from my spare hard disc to draw from my backup.
Kindly guide me please.
Narayanan Lakshmanan India
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
First, LOL.
IFixit ships worldwide. You need to swap the case? or not? You are confusing me.
A battery is pretty straight forward in the guides here.
On stopping using icloud I cannot help you here.
这个答案有帮助吗?
得分 1
5条评论:
Please help me with the battery issue.
Regarding, iCloud it can be dropped and I will put forth a separate question
完成的
What is your battery issue? What do you mean WITHOUT the case. Check the guides please!
完成的
I will enclose the health card of my battery it needs to be replaced. I understand the outer case also has to be changed, I’m not sure what it means since this was said by the concerned service provider.
Screenshot 2019-06-02 19.36.14
完成的
hahahahhaha, This dude went to the Apple Store!
Did you see the cbc guy for a bent pin got charged for MOBO WATER PROBLEM SCREEEN. he took it to papa Louis Rossmann he had just bent a pin and it worked.
Never trust those greedy bastards. I can’t see the screenshot. Buy this MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery. easy to put in
完成的
@tomfixee - Lets not berate people!
People come here because they just don’t know how to get to the answer. Sometimes the language differences can get in the way.
Hammer the problem not the person!
完成的
添加一条评论
Narayanan - You don’t need to replace the uppercase if the battery only needs to be replaced.
But! If you don’t follow the guide correctly you can damage the keyboard if the solvent gets into the keyboard.
If you think your keyboard is having issues you might want to let Apple fix your system. The Apple Stores only replace the uppercase for either failure. So… If you have bad keys there’s a good chance you’ll get both fixed for Free! Keyboard Service Program for MacBook, MacBook Air, and MacBook Pro and there is a second repair program for the stage light problem 13-inch MacBook Pro Display Backlight Service Program
In any case make sure you take out the solvent as it can’t be carried on the plane. Have your friend take it out before flying back and he needs to hand carry the battery onboard in the box.
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery图片
产品
$129.99
这个答案有帮助吗?
得分 1
1条评论:
If you consider only the thingy that the bits go in costs 6+ dollars with tools is worth it
完成的
添加一条评论
添加你的答案
NARAYANAN LAKSHMANAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 112
