跳转到主内容
加入维修社区 - 创建账户
The Capresso Infinity Model #565 is a conical burr grinder that is used to grind coffee beans varying across sixteen settings from Turkish fine to coarse.
I can't adjust coarseness after reassembling the bottom burr
I removed the bottom burr of my capresso infinity for cleaning, and ever since reassembly it has been grinding coffee on only the finest setting, even when the dot is twisted to the coaresest setting. I suspect that whatever mechanism that adjusts the distance between the burrs is not working. What could I have reassembled incorrectly? I suspect it might be the ball bearings and springs - how are they meant to sit?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I figured it out. We'd placed the springs and ball bearings correctly under the burr (first the springs go in, then the balls) but we hadn't aligned the top plastic piece above the burr with the bottom one that the burr sits on. There is a tiny notch that needs to fit together, and you can't feel it by spinning them together because they don't touch until everything is screwed and tightened. You have to look to make sure they're aligned before you start screwing everything back together. Hope this helps someone.
This video and the comment thread helped us figure it out: https://youtu.be/lC2eRr5kbvY
这个答案有帮助吗?
得分 3
2条评论:
yes, thank you. i did the same thing and have been searching forever trying to figure out what i could have done wrong. personally, i think the design could have been a little more user friendly.
完成的
I watched the video and see lining up the start of the gap in the black ring, but not sure what that has to do with the springs and ball bearings.
完成的
添加一条评论
添加你的答案
Liz Steinberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 1,629
