Low boost clocks and high temps in Cinebench
I’ve got A1398 Late 2013 with 2.6ghz i7-4960HQ. Thermal paste apparently wasn’t swapped it’s entire life. In Cinebench it was reaching 95-100 degrees and 2,8 - 2,9 clocks. CB score - 540 or even lower.
I changed the paste with Cooler Master V1 IC Value. And got… 95-100 degrees and 3.0 boost clocks AT MAX. CB score 580 0_0
This model must give about 640! What the heck is that? I didn’t make any nooble mistake I bet, I did everything right. I even reapplied the paste to be sure it’s not my fault. Nothing changed, it works slower than it must and even gets hot while FF playing video.
What could be? Never stumbled upon anything like that
Before CB:
While second run launched instantly after the first
3条评论
Lets get a better view on things here, install this app TG Pro its one of the better monitoring apps. Wen the system is idle take a snapshot of the main window, make sure you grow it so all of the sensors and fans are visible. The do a second snapshot capture just after running Cinebench. Post both here for us to see 在已经存在的问题里加入图片
由 Dan 完成的
Done
(I have to write something to make my comment longer so the site passes it :D)
由 Anri 完成的
Your cool ;-}
由 Dan 完成的
