跳转到主内容
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
267 个问题 查看全部
Controller charges but does not turn on
After i cleaned it with alcohol it didn’t turn on at all. It just charges. After a teardown i didn’t notice any physical damage. I think that the flexible pcb doesn’t make contact with the board. I also have the older dualshock 4 and they both failed at the same time. The old model doesn’t give any light when charging but the newer model all the ports work.
So the main thing is that they don’t turn on none of the buttons are working and there is no sign of liquid damage or other stuff
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Also when i push the reset a extremely low brightness green light comes on
完成的
添加一条评论
2个答案
Can it connect thru usb?
这个答案有帮助吗?
得分 0
添加一条评论
Yes to my pc but not to the ps4
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Reverse Gamer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 66
