跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
iPhone stuck in setup mode because sim card is still "searching"
I went to the beach the other day with my sister out of town, and mistakenly dropped my iPhone 7 plus in the water. i quickly dried it off with my towel. Everything was going fine until I noticed the screen going in and out. So i then powered off the phone and took my case off of it while I waited till I could get back to my car. The car ride back home was crazy because the phone stayed stuck on the apple logo and at this point i had no way to go online to figure out how to fix it so i just waited till the phone died. When I got home i tried to put it the charger and i noticed it took longer to charge then usual. Tired at this point i feel asleep while the phone “charged” the phone stayed on “1%” the whole night. When i woke up the next morning I tried to use my phone. I also noticed i couldn't do anything with the phone unless i kept it on the charger every time i used it. At this point i noticed that my service was gone and it kept saying “searching”. So i decided to reset the whole phone after i backed my pictures and videos up when i should have just reset the network settings. (At this point its past two days and on the second day i let the phone air dry because i read using rice would be bad).............. (which brings me to my problem)............. As i go in to set the phone back up i get stuck on the “set up manually” part because it can't read my sim card and says “searching” still. To make sure my sim card wasn't damaged i put my card into my brothers phone and all of my unread messages started coming in to his phone. So i know the sim card works its just my phone is battery damaged (i know i can fix because of your website) but i don't know how to fix the sim card problem. I can't get past the setup part to even try to do a battery replacement on my phone. PlEASE HELP i will greatly appreciate your advice.
*That screenshot was before i reset my iphone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Never let dry liquid inside, and is worse when is salt water like a beach water. You have to open it a clean it. About Searching Issue, can be corrosion on simcard pins or BASEBAND problem, if your phone does not have IMEI number (you can check it under settings about or pressing *#06# on phone app.) will be a problem with your BASEBAND chip or some component near to it. If that is the case you will need learn about microsoldering and get some tools for it, or you can start searching a store near to you that do this kind of work. There is a lot for documentation for Apple Products repairs the chances to fix your phone are high.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jena 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 189
