跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 个问题 查看全部
Device is connected to wifi but no internet.
Hi everyone,
I recently changed my keyboard and after that everything is basically messed up with my MacBook!
First one is: System is successfully connected to WiFi but it has no internet.
Second one is: System doesn’t remain on unless I plug into charge.
I’ll be happy if anyone can help.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
A common issue is pinching the antenna cables when you remount the logic board. While you were able to get a basic connection it is not strong enough for a full data stream to get across. Pop off the logic board and check your cable routing. You may need to replace the antenna unit. Also make sure you got the correct antenna onto the correct port on the AirPort board.
For your power issue lets get a better view of your batteries health and the charging logic. Install this gem of an app CoconutBattery take a snapshot of the main window and post it here for us to see 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Amir Charmchi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 56
