跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
Track pad not clicking.
My trackpad has been acting weird lately. It registers click, but it doesn’t physically click. I even opened up my MacBook and cleaned all the debris below the trackpad, but after reassemble, it is still the same. Is there a tension screw on this MacPro model too? and if there is which one is it? and what possible solutions are there to make it physically click again..?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
There is no physical click, the clicking feel is simulated by the Taptic Engine module underneath.
Surprising that this has tricked so many people up till now.
It is likely that the Taptic Engine motor is stuck, or the driver fried. In any case you need to replace the trackpad unit.
这个答案有帮助吗?
得分 3
2条评论:
so if I buy a new trackpad and replace it, it would be just fine. is that correct?
also just figured out that my force touch haptic feedback is not working even after the smc reset. is this because of the Taptic Engine too?
完成的
Yes you need a new trackpad heres the needed part: MacBook Pro 15" Retina (Late 2016-2019) Trackpad and here's the guide to replace it 2016年末带Touch Bar的15寸 MacBook Pro 触控板更换
完成的
添加一条评论
添加你的答案
Minsoo Kim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 739
