跳转到主内容
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
857 个问题 查看全部
I have a general wiring question about ignition wire harness?
I am actually working on a dixon ztr 308 zero turn mower and am wondering if I have to use a wire harness to connect keyed ignition switch or if I can wire strait from ignition to solenoid, magneto, and ground? Is the harness just for a quick disconnect?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you for the confirmation all the wires were corroded and direct wired now with better quality wire. Runs great now
完成的
添加一条评论
1个答案
已选择的解决方案
A harness is for consistent easy assembly at the factory. You can direct wire with a connector or not. The ZTR 429 I’m rebuilding wouldn’t engage the blade clutch, the connector was so badly corroded. I bypassed it using wire nuts. Now waiting on new drive cones to finish the rebuild.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Wesley Neal 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 57
