It sounds like there might be an issue with the right Galaxy Bud. Here are a few steps you can try to fix the low volume issue:
1. **Clean the Earbuds**: Use a soft cloth or cotton swab to gently clean the speaker mesh and the area around it on the right Galaxy Bud. Sometimes, dirt or debris can block the sound.
2. **Reset the Galaxy Buds**: You mentioned you've already done this, but just in case, here's how:
- Open the Galaxy Wearable app on your phone.
- Go to `Settings` > `Reset earbuds`.
3. **Check for Updates**: Ensure your Galaxy Buds and the Galaxy Wearable app are updated to the latest version.
4. **Bluetooth Settings Reset**: Try resetting the Bluetooth settings on your phone. This can sometimes resolve connectivity and performance issues:
- Go to your phone's Settings.
- Tap `Connections` > `Bluetooth`.
- Tap the settings icon next to your Galaxy Buds and select `Forget`.
5. **Reconnect the Galaxy Buds**: After resetting Bluetooth settings, pair the Galaxy Buds again with your phone.
6. **Equalizer Settings**: Check the equalizer settings in the Galaxy Wearable app. Sometimes, adjusting the settings can improve the audio balance.
7. **Contact Samsung Support**: If none of these steps work, it's possible there's a hardware issue with the right Galaxy Bud. Contact Samsung Support or visit a service center for further assistance.
Hopefully, one of these steps will help resolve the issue with your Galaxy Buds!
30条评论
My left bud does this
由 Jake Freed 完成的
My left bud is doing this but for some reason that bud has a much tighter fit even when I swap the ear tips
由 Superior Monkey 完成的
Same thing is happening to me. My left bud is now a lot quieter than my right bud.
由 Andrew Hardie 完成的
I had the same problem. Tried all the "soft ware" fixes to no avail.
I took off the little silver screen cover. Removed the black mesh behind it, and replaced silver screen. Solved the problem. Sound is great.
由 Chip Drinkman 完成的
Hey everyone, I have a fix that might help. I assumed it was a software problem with my buds too. I did the thing where I pulled the mesh out and all that and still had the problem.
Here's how I fixed it:
With the mesh attached in the earbud, I wiped it with rubbing alcohol, and then used an air duster can to blow directly into the mesh. Voila my earbuds were good as new.
由 Brian Maldonado 完成的
显示更多的25条评论
