跳转到主内容
骑记电助力折叠自行车是小米第一次进入电动自行车市场的首款商品。 拥有250W高速电机,配备松下18650锂电池组。 禧玛诺内3速花鼓 以及力矩传感器,一次充电可以助力骑行45km。 它同时配备有行车电脑可以将您的手机通过特别的应用连接。 同时自行车也是可以折叠的。
My Qicycle suddenly has no power assist
The battery level shows it is full and the LCD display shows up normal. Now it is just an ordinary bike with no power assist. The LCD display still shows the speed and watts of the bike when I am padel the bike. The bike has only 150km. Which component I should replace first or how to narrow down the faulty unit? Bike Control unit, torque sensor or the motor?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I have gone through the IFIXIT tear down tutorial of the bike and there are no fuse to replace.
完成的
添加一条评论
9个答案
最有帮助的答案
Hi, did you solved the problem? I have same one…
这个答案有帮助吗?
得分 1
8条评论:
Problem solved! Brake sensor was defected. If there is someone who will have the same problem, just try to disconnect the left & right brake sensors (connectors) between pedal...
完成的
Si,correcto. Sólo desatornillé el sensor del freno izquierdo y funcionó,gracias.pd. Error de fabricación
完成的
what brake sensor are you talking about ?
完成的
@Michal Procházka : what break sensor ? mijia qicycle only has manual break. is there any sensor ? where? can you post a photo here, please ? thanks
完成的
Hi, I have brake sensors under brake lever. The sensors scan brake lever level and when you are braking, it send information to the controller and then controller stop output power to engine... But I have EU version, so, If you haven't wires under brake level, you probably don't have brake sensors.
完成的
显示更多的3条评论
添加一条评论
Watch YouTube for Xiaomi qicycle fr Dyson bike they found the sensor plug just need tighten n simply…I fixed mine hope it helps
这个答案有帮助吗?
得分 1
2条评论:
Chinese qicycles dont have brake sensors...
完成的
My qicycle has wires coming out of the brake levers right and left.
完成的
添加一条评论
I have the same problem also. Several e-bike service center don’t know the problem. They said xiaomi too complicated bike and no parts available in my country (jakarta - indonesia). Yesterday I went to another e-bike service center. The technician said he will check one by one. And just know he texted me, he found the problem. It is THE CONTROLLER. And now he is trying to replace with the one that he got in his store. Yes, he will try to modify or whatever to fit the new controller. I hope this will work.
这个答案有帮助吗?
得分 0
6条评论:
Hi there, i am.living in Jakarta and I have the same problem. Please advise me your ebike service center. Thx
完成的
Trektown. Please check via google. The phone number I got from google. The technician name Abenk
完成的
Hey, would you be willing to share your contacts for the e-bike service center in Jakarta?
完成的
The store name TREKTOWN at Lebak Bulus. You can google for the right address. The technician name is mr. Abenk
完成的
My qicycle now work perfectly. The problem is the controller. It is locate beside the battery. Only good technician can take it out and fix it. The technician told me to be careful with the controller by not push the bike to hard. It means we cannot use gear 3 when the street is high. Use gear 1 and push the pedal wisely. I hope you understand my english.
完成的
显示更多的1条评论
添加一条评论
i‘ve had this problem two times.
First time the mud defender i have installed killed one little cable between the motor and the controller. The second time it was more difficult. qicycle app beta told me that one battery cell had 41volts, the other 0 volts. ….but the battery was working in another bike.
I have changed the integrated cable, then the controler, nothing. At last i have changed the computer at the handlebar. That‘s it. The computer was okay, only the yellow cable was broken. Folding a bike is no fun for the cables.
Hope i could help you.
这个答案有帮助吗?
得分 0
添加一条评论
You have to check the controller. And… it really hard to check it. It locate behind the front lamp. Only an experiece tehnician can do that.
这个答案有帮助吗?
得分 0
添加一条评论
Hallo!Ich habe das gleiche Problem,habe Controller und Display getauscht aber will nicht Funktionen.Kann Mann für normal Fahrrad benutzen.Wo hat Fahrrad Problem,was soll ich tauschen…Motor..oder welche Sache?
Danke euch.
这个答案有帮助吗?
得分 0
添加一条评论
Has no power
这个答案有帮助吗?
得分 0
1条评论:
My e -bike folding: has no power?, the monitor show me on!, but, no power??
完成的
添加一条评论
First, remove the battery block and apply electrical tape along the channel on the side. This will ensure a tighter fit. Additionally, clean the cable connectors.
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem - all well, but no power assist. There's a Youtube video that solved that problem when he discovered that the sensor sender (?) that comes from the brakes and is screwed onto the bottom of the big frame bar had gotten loose; he screwed it down and all was well. I didnt have that, but I thought that maybe the brake sensors at the handbrakes might be a problem. I unscrewed them - they are the little ~4 cm long plastic square bars, one each on the bottom of the handle bars, with a wire each going to the aforementioned sender, held in place with 2 tiny Allan screws. And Voila! Motor assist came back. There is absolutely no skill involved, just a lucky (I hope) guess. But it sure made my day for finding service for this bike in Holland is not easy -which is what prompted my desperation try.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sinclair Yung 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 124
总计 9,727
