Rear camera and torch not working
I can’t remember the exact cause of when this started happening but I have a feeling it occurred after dropping the phone on its front face.
At the moment only the front facing camera works and the rear facing camera only works in 2x mode. So portrait mode just shows a black screen. While in 2x mode I can get the camera flash to work fine but for some reason the torch won’t activate even though I thought they have the same output. I’ve already tried to do a hard reset and also restored to factory setup with no luck. Is this likely a hardware problem? Any help would be great thanks.
1条评论
Hello. Do you solved this problem?
由 Jacob 完成的
