跳转到主内容
Xbox 360, Xbox One, Series X|S 无线控制器的维修信息和拆解指南。
Xbox One controller A button won't work
Hello iFixit fellas.
I'm reaching you because i have an issue with One of my Xbox One Controller.
A button won't work.
Things i've done :
Teared the entire controller apart.
Cleaned the rubberised contact pad, making sure not to scrub to hard underneeth to avoid removing the graphite coating (which makes contact with the PCB.) With Q-tips and isopropyl alcool.
Cleaned up the PCB lightly scrubing with a toothbrush and alcool.
Reassemble the pad -> Nothing. Every button worked exept A.
Teared down again, removed the A plasitic button + rubberised pad, reassemble the controller again. Leaving an hole where A is on the PCB.
I tried to make contact on A with a Q-tip + aluminium foil. Nothing.
I teared the Controller apart a third Time and then i discovered this
So, maybe the traces are broken even tho i don't think they are connected or even, corresponds to the A button.
Here's the area behind A (SW11)
Do you guys know the test points for the A button ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If your Xbox One Wireless Controller has sticky or broken buttons, see the Xbox One Wireless Controller Has Sticky or Broken Buttons problem page for possible problems and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
My Xbox controller's "a" button is pushed in way more than the rest and won't raise up, and is very sensitive to touches, can I get help? I really need it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thomas Dangest 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 821
