跳转到主内容
Can I use a US/UK Layout Backlight on a German Keyboard
Hello,
I want to ask you all if i can use a US/UK Backlight foil on a german keyboard.I ask you because the shift and Enter-key differs from the german layout.
Thanks for your feedback
Chris
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It will fit but you may see that the backlight is not uniform with the enter key. A small minor thing but unless you absolutely need to change the backlight I would keep with the original backlight film.
We re-use the backlight film a lot for keyboard replacements from liquid damaged MacBook Pro Retinas as long as they are removed carefully without ripped backlight layer they light up fine.
Edit: I do see two minor rips but it still should be OK to re-use.
这个答案有帮助吗?
得分 3
5条评论:
Hi Ben,
Thanks for your response, the problem is that the original backlight is faulty and I want to replace it.
I ordered the german layout, but received the US one.
Not sure what to do…
完成的
It can still be used, lighting will look a bit weird on the enter key. Might want to talk with the seller and tell them that you've received the wrong keyboard layout and see if they will re-send the correct one.
完成的
I have already contacted the seller, unfortunately he does not have a DE layout anymore. So far I couldn't find a shop selling a GER/EU layout.
Therefore I struggle if I should install it. Have you ever seen a photo or a US backlight on an EU Layout?
完成的
Chris - Is this what you are looking for? Retina MacBook Pro 13" Keyboard Backlight Sheets - ISO
For - Apple P/N B661-8154 keyboard (British) How to identify keyboard localizations
The Letter defines the keys and the layout. Any of the EU (ISO) keyboards will work you would only need to swap out the keycaps if you got the full keyboard.
Here we are getting the backlight which is the same with all of the ISO layout keyboards.
完成的
Thats it, Thank you very much - i ordered it.
完成的
添加一条评论
添加你的答案
Chris Feeser 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 1,285
