跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Keyboard and Trackpad doesn't work since I replaced the battery
Hello,
Since I’ve replaced the battery by a new one, both trackpad and keyboard doesn’t work. I tried without battery and with my old battery but I got the same issue. So I bought a new trackpad cable and the trackpad and keyboard are still inoperative..
I can use the mac just with a extern mouse and keyboard. I’ve tried SMC, PRAM, delite .plist and nothing work.
Thanks for your help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I would replace the Retina MacBook Pro 13" Trackpad Flex Cable cable which is a common failure on this series. The symptoms you describe where both the keyboard & trackpad are not working centers around either the cable or the trackpad as its the common points for this problem.
这个答案有帮助吗?
得分 2
7条评论:
I've already replaced this cable unfortunately… I ordered a other one in case of the first is broken.
完成的
OK, Good! So your MacBook Pro 13" Retina (Early 2015) Trackpad needs replacing. The trackpad in this series is a junction point for the keyboard so when both fail its either the cable or the trackpad its self.
Look at the pins to see if you see corrosion or bent pin.
完成的
The trackpad looks good, it can't be a software issue ?
This trackpad is good : https://www.ebay.com.au/itm/Genuine-Trac...
完成的
Run diagnostics if you can. Restart the system press the ‘’’D’’’ key. Any errors?
I can’t see this as a software issue. It’s always hardware from all of the systems I’ve done.
完成的
No error found during the diagnostic. So it's necessarily the trackpad ?
There is no trackpad available in the ifixit store (Australia), the trackpad that I mentioned is good ?
Thanks fo your help
完成的
显示更多的2条评论
添加一条评论
最有帮助的答案
Check for any dislodged / missing components near the edges of the main logic board where you may have possibly used a pry card around those areas as that’s the only other thing I can think of that’s causing the keyboard and trackpad to stop working.
这个答案有帮助吗?
得分 3
1条评论:
I've checked and nothing was dislodged.
完成的
添加一条评论
添加你的答案
pierrebouaye44 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 242
