跳转到主内容
Oppo 手机维修指南。
390 个问题 查看全部
Why is my phone oppo A3s on blank/black screen? How to fix it
I was charging my phone for a few minutes because it was almost dead. After a while someone was calling and my phone was just blank. I unplug it and it vibrates, someone calling me and it keeps ringing so I know it still works but my phone has black/blank screen. How to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
if You Want To Download This File https://www.officialroms.com/oppo-a3s-fl...
完成的
添加一条评论
5个答案
已选择的解决方案
To reboot the phone try holding power + volume up and home button to hard restart the phone hopefully that is enough to fix it. If that doesn't work try volume down as well.
这个答案有帮助吗?
得分 7
7条评论:
i did but it still blank it just vibrates
完成的
Same with my oppo AX5s
完成的
Even my Oppo A57
完成的
oppo phone from china sucks
完成的
Even I m facing the same issue with my Oppo F7... If u guys get the solution.. pls share it !!
完成的
显示更多的2条评论
添加一条评论
Download OPPO Latest Version Firmware & Flash With This Firnware Check Out: Link
这个答案有帮助吗?
得分 1
添加一条评论
Very Simple Solution Download Firmware & Flash Full Process With Video Click Here
这个答案有帮助吗?
得分 1
添加一条评论
OPPO Latest Flash Tool
这个答案有帮助吗?
得分 0
添加一条评论
My phone screen not working but the sound working.. How to i open my screen turn on in oppo A5s
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kathleen Tonido 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 158
总计 15,687
