跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Unresponsive touch after a screen replacement.
So I have an iPhone that I replaced the screen on a couple of times. (Friend doesnt want a better phone case) but the screen has been having issues with touch around the center left area on the screen. I got the screen from iFixit and am not sure if I need to get a new one from them or if it's another issue going on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
the old screen still working? you can try to isolate the problem, if the old screen still touching basically is a bad screen.
完成的
添加一条评论
1个答案
已选择的解决方案
1st) try the old screen (if it still works) and see if the touch function is normal.
2nd) If it works normally, install the new iFixit screen and see if the touch is still finicky. If it still has issues, you should order a new screen.
3) If after your repair neither screen works (the old one or the replacement), then there may be something stuck in the connector (ie. adhesive, dust) or possibly a damaged prong, or worse, a damaged board. In that case, a new screen isn’t going to help you.
Best of luck! Let us know what the result is!
这个答案有帮助吗?
得分 1
1条评论:
Thanks for accepting my answer! If you have a moment, let us know what the result of your troubleshooting was! Thanks again!
完成的
添加一条评论
添加你的答案
Fredrick Rios 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 6
总计 68
