跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
What’s this chip burnt on an A1502
Hi. I have MacBook Pro A1502.
Can see this chip burnt out could someone tell me what component it is?
Thank you you for any help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
That’s ot an IC, it appears to be a capacitor of some kind. It’s probably to help regulate the backlight controller. Is your display bad, because you can just order a replacement on iFixit. Otherwise I wouldn’t worry about it.
完成的
添加一条评论
1个答案
最有帮助的答案
It’s an inductor for the 1.5V S0 Rail which means there is probably a short along that line as that has blown. Replacing that inductor will not fix the problem as you’ll need to find out why it blew up in the first place.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Luke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 98
