跳转到主内容
Ghost touch on top right side of screen
Bought a used ipad pro and thought I checked it out pretty well before purchase but not well or long enough apparently, (I've bought cracked iPads in the past with no issue so this took me by surprise and I'm wondering if the fact the ipad pro is more sensitive plays into it)
It has a small less than an inch crack in the top right corner which is where I think the ghost touch is coming from, it effects about one inch down and goes to the mid point of ipad, I normally throw up split screen and an app that it can play without distracting me from my work but I'm hoping to get it fixed soon
Wondering if this a digitizer issue, a wire issue, or a faulty processor?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It’s the screen going bad. Is it a glass crack that you can feel by running a nail along it? If not it’s on the touch screen layer under the glass surface.
这个答案有帮助吗?
得分 2
添加一条评论
tow possibility
either the touch damaged and you will need to change it
either the touch ic damaged
and both need good skills to fix
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
E william 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 317
