跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
power button - problem with button after fixing
Hi,
I have 3GS, in order to use the power button, u need to press really hard, in some point, and then it works (With pinching as well).
Volume buttons, headset, silent switch are working.
I opened the device, cleaned the button and the flex, made sure the button is in 180 to the back panel - but it didn't work.
what could resolve this?
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Simple fix. This issue is not the button itself, it will be the flex beneath it that is the issue.Try to find some rubber of some sort that wont degrade. When i have come across this issue i use the rubber from HTC home buttons. Cut a very small piece out (approximately the size of the home button flex (pictured below)
Use some fast drying glue/super glue and glue it inside the small circle. Make sure you are carful as you only have one shot at this as super glue dries very quickly. But don't worry too much if you break it as it is already possibly broken. Put the rubber in place and wait minimum 5 minutes for it to dry. Replace ribbon and home button and hope for the best! If it still does not work you can either buy a new Headphone jack assembly and install (make sure you know what you are doing before carrying out this type of part replacement as it is rather difficult) or you can buy a new back assembly and it will be pre-installed for you.
Headphone jack assembly -
iPhone 3G/3GS Headphone Jack Assembly
Back assembly -
http://www.macfixit.com.au/shop/index.ph...
Replace a dirty or corroded headphone jack, or a damaged internal audio or power button switch.图片
产品
$14.99
这个答案有帮助吗?
得分 1
2条评论:
Hey martin,
Well.. The HTC tip is not possible cause I don't have it, plus I am not sure I understood.
But I would like to ask something else about the Headphone Jack Assembly:
Replacing this part to a new one, should I be carefull with something?
I understood that the Vibrate area has the mute button and some other parts that must be there and you must work very carefully there.
Thanks
完成的
Yes, below is a link to another post that has had a similar issue and i explain the issues with the ribbon in further detail. If i were you i'd just buy a new back assembly and be done with it. A lot easier and a lot less time consuming! Trick to getting the mute switch to stay in mute button?
完成的
添加一条评论
添加你的答案
Shai 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 11
总计 1,701
