跳转到主内容
Water damaged now my phone screen works automatically
I have redmi 5a phone . I got some water in my phone about 6 months ago but now my phone screen works automatically sometimes.when I do a screen test it shows a vertical line blinking in the lower part of the phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
But ... changing the screen will not solve the liquid damages. You should clean it before changing any circuit or part.
这个答案有帮助吗?
得分 2
1条评论:
True and I think the best liquid to clean it with is with 99.9% alcohol
完成的
添加一条评论
Try doing a screen replacement. If that doesn’t work, try checking for bad connections on the Logic-Board. If you found some, try replacing the logic board. Personally, I think that the Logic Board replacement will be obligatory since the one your using will probably have board-level water damage.
这个答案有帮助吗?
得分 1
添加一条评论
Change your screen display bro
While changing you could learn more about your phone... Please checkout link given below
https://youtu.be/4LCO5Ik6QzA
这个答案有帮助吗?
得分 0
添加一条评论
Redme 5a
switch on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sahil sharm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 47
总计 436
