跳转到主内容
Released on February 25th, 2013. 10.1" Tablet with Android Operating System, ARM Cortex A-7 Quad Core Processor.
28 个问题 查看全部
My tablet is not charging and quickly heating
i had broken my charging port.after i fix it.i have check it throug come 5v positive line.. but it not charge.. i want to know how to bypass charging port.. and i want to know it has a any other solution. thank you …
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
thank you..!
完成的
添加一条评论
1个答案
最有帮助的答案
Is the replacement port the same amount of pins and the same orientation? Ones that are flipped upside down can’t be used as they route the pins opposite to where they are supposed to link to the board.
Another thing I do sometimes if needed is jump start the battery I inject 3.7-4.2v on the + and - of the battery’s to externally charge them via a DC bench power supply. Voltage may vary depending on rated voltage of the battery.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Kelum Aruna 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 88
